If-Then construction within Templater Suggester function
I’ve tried experimenting with my current code and searching on javascript sites, but I’m not a coder so unable to make too much progress. Of course, have scoured the obsidian forum…
I’m trying to optimize my use of Suggester within Templater. Currently I use the following which allows me to choose the Fund I want to write about:
<% (await tp.system.suggester((item) => item.basename, app.vault.getMarkdownFiles().filter(file => file.path.startsWith(“020 Investments/Funds”)))).basename %>
However, I’d like to be able to utilize an If-Then construction. IF it’s a Fund, then choose one folder…IF a Business, then choose another folder. Put another way, I’d like my answer to an initial suggester (“Is it a fund or business”), determine which folder suggester points towards for the following variable.
It sounds like this should be doable, using a little javascript inside a <%* %> block.
The way I’d tackle it would be:
  • set the selected value of the initial (“Fund” | “Business”) suggester to a variable
  • check the value of that variable against your logic
    • use an if-then or a switch-case structure to send out the second suggester with the desired options (using your same logic as above), setting the selected file’s basename to a new variable
  • from there you can use the new variable to add the text into the note with the line ‘tR += whatever_you_named_your_variable’
Apologies for the poor formatting, I’m relatively new to using forums like this one.
I’m also still new to Obsidian and I’ve been feeling my way through everything, but I believe this should work. I hope that helps some!
Thanks very much - I’m going to continue to work may way through this challenge. Best of luck getting up to speed in Obsidian - it’s great !
