Obsidian 0.14.6 - 0.14.6 installer
This is a relatively recent change because I just started noticing it and I’ve been doing it this way for a long time.
Something I do fairly often is replace links with updated links or correct the link text (in between the []'s)
So I usually copy the new data and the drag to select the part of the link I want to replace, and then paste with Cmd-V.
There’s been a recent change where, if I down click and start to drag with the mouse to select a portion of the text within the link to be replaced, if I press the Cmd key before releasing the left mouse button (in preparation for typing Cmd-V) Obsidian will follow/open the link which should not happen since the Cmd key modifier was not pressed on the down-click. This is contrary to standard OS behavior. Doesn’t happen in Chrome either or older versions of Obsidian.
