I want a method do create a checkpoint inside a note so I know that I need to continue later.
I tried using the #continue tag, but this creates so much pollution since many notes in many different folders would have the tag.
Maybe I could use Dataview on each note to check for the #continue tag, but I didn’t manage to make it work.
How do you create your checkpoints?
Search is really good in Obsidian, so anything unique works. I’ve used tkk
and kakunin
(Japanese for review, confirm) dropped randomly in note to remind me to go back and check something.
I also use single brackets for words or phrases that could be omitted. e.g.
..text someone at the last minute [if you were running late].
or for the best option to choose later:
This meant that [you / people] always had to...
You can combine them: [tkk-railway-name-at the-time]
An added bonus using single brackets [...]
; they are considered “bare links” and you can target them with CSS to change the styling of the text if you’d like.
Ok, but it would be the same as using tags, it’ll show everything in all the folders.
There’s a way to filter by folder?
Edit: Yes, there are!
And I created a bookmark with the results of the search, now I have quick access to them.
Would be perfect if I could attach this bookmark to a note.
Anyway, thanks for the tip, helped me to find a solution.
Exactly what I wanted, except for the folder filter, it’s showing my whole vault, I’m trying to fix it with Bard.
gino_m
January 9, 2024, 10:59pm
7
henrique:
On how to specify a folder, see further above:
Probably somewhat of an overkill (I’m not much on javascript myself), but you can use something like this:
```dataviewjs
// Query all pages
const allPages = dv.pages("");
// Crawl content and render list
const pages = await Promise.all(
allPages.map(async (page) => {
const content = await dv.io.load(page.file.path);
const regexPattern = /.*\bSEARCHTERM\b.*/gm;
const regexMatches = content.match(regexPattern);
if (regexMatches && regexMatches.length > 0) {
It’s working now, but the tag symbol #
bugs the search, I’ll have to use a unique word instead of a tag, but it’s still an amazing code!
Thanks very much for the help.
gino_m
January 9, 2024, 11:48pm
9
I had a similar requirement in the past and used a (different) DVJs query to put in a table files containing a hashtag+keyword combo.
I just tried the code with this combo of mine and I have no problems. I’m using the proper highlight syntax (see: '==$&=='
in the code).
system
Closed
April 8, 2024, 11:48pm
10
