Iconize Plug-In, Help Please: Custom Icon Pack Icons Do Not Change Color
Hi!
I know this is a plug-in question but I couldn’t find a fix on the GitHub and Iconzie Help page. I’m using the Iconize plugin and all of its own Icon packs work wonderfully, natively change color so they match with the text colors I have set using Style Settings and allow me to manually change individual icon colors too, and I use the Plug-In a lot to help with organization and general aesthetics of my Vaults.
I’ve wanted to experiment with adding my own custom icons. I have the svg files saved and uploaded, and I can use custom icons like the rest; the only issue is that the custom icons do not natively match the text color nor do they respond to me manually changing their colors either. I find it a little jarring and would like to be able to, at the very least, be able to set colors manually.
I am rather certain this is entirely a me-issue. Regardless of the Obsidian or Iconize versions, and there have been no updates that clashed with my ability to use Iconize’s premade icon packs, so I do not believe the inability to change custom icon color has anything to do with the software or the plug-in itself.
Thank you for your time and help.
