Its not compatible with make.md i guess?
I cannot change properties icons nor make rules work for any folder / type.
Hi @Holo. Thanks for the plugin. I’m trying to use it with the Blue Topaz theme, that should be compatible AFAIK, but for some reason the icons don’t appear and I just see some empty space:
Should I do something to fix that?
Thanks
Hello. Thank you, this plugin looks promising.
I personally like ability to use tags and properties in conditions.
Do you plan or is there FR to add ability to show file’s icons not only in tab and file tree, but inline, everywhere where there is a link to a file having an icon, as it is done in Iconize?
Ability to show icon near inline title would be great as well.
that’s make.md for you. You could try asking in their Discord server.
