I have to insert template twice for it to fully insert
  1. Create a template folder
  2. Assign the template folder in settings
  3. Create a template with the following text (need to be in source mode)
Date: {{date:YYYY-MM-DD}}
^ [[Active Repairs]]
- [ ] ==(is this still active?) ==
  1. Create a new file and try to insert the template.
  2. Realize not everything inserted and insert again.
  3. It kind of works if you insert twice but the spacing is wrong.
Yes
It should insert the whole template on the first try
It is not inserting the template fully on the first insert, and when you insert it a second time the spacing is wrong.
Obsidian version: v1.7.7
Installer version: v1.6.5
Operating system: Windows 11 Enterprise 10.0.22631
Catalyst license: none
This is the result of inserting twice, notice the spacing is wrong.
This is the template
Thanks,
Boaz
Hello
Intriguing. All of the versions below work. Doesn’t seem to like consecutive lines of triple hyphens. No idea why. A conflict with setext headings?
Hampton,
Thank you for this solution!
Weird that the bug exists but this definitely solves it for my use case!
Thanks,
Boaz
It would help to show an example of what happens when you only insert once.
In the hope this helps—only the YAML header is inserted (the dash below is just the cursor flashing way):
insert once
Thanks, I’ve identified the issue. Will be fixed in a future update
