I have a display problem in my left column
Hello everyone, since the last obsidian update, I have a display problem in my left column. The letters do not appear. It’s the same on computer, and IPAD.
Would you know what to do?
Thanking you, see you soon, Dimitri
Is the installer up to date?
Hello, it’s: Version 1.0.3
This problem has come up a few times since Version 1.0 and it has always been the theme they are using.
Check if your Theme needs to be updated. If there’s no update, switch to default theme and see if the problem persists.
Hello.
As the installer is up to date, I suspect that @Olondre is right: the theme is probably causing the problem. Hope you find a solution.
Also check the installer version. There’s an app version and installer version. Installer version is important to ensure ur electron (basically a chromium) is the latest. Sometimes that can be the issue like this situation
THANKS everyone! problem solved, it was the theme that was not updated, THANK YOU thank you thank you! see you soon !!!
it was the theme that was not updated, REDGRAPHITE for obsidian,
