type <http://www.example.com>
that the full “<http://www.example.com>” would be the same color
the “>” of “<http://www.example.com>” is the normal text color, while the rest is the links color.
- Operating system: Arch Linux
- Debug info:
Obsidian version: v0.14.5
Installer version: v0.13.23
Operating system: #1 SMP PREEMPT Mon, 28 Mar 2022 20:55:33 +0000 5.17.1-arch1-1
Live preview: off
Legacy editor: off
Snippets enabled: 1
Safe mode: off
Plugins installed: 4
Plugins enabled: 0
Custom theme: for cosmetic issues, please first try updating your theme to latest. If still not fixed, please try to make the issue happen in the help vault or disable community theme and snippets.
ctrl+shift+i shows the starting < is placed into a span and has the correct classes applied, but the ending > is just the character with no wrapper
