- Open a sandbox vault,
- Write something in Markdown,
- Write a callout, with a code block inside containing HTML code,
- Write something else in Markdown
You can copy and paste this :
# Lorem ipsum
Lorem *ipsum* **dolor** sit *amet*, **consectetur** adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
> [!IMPORTANT]
> Lorem *ipsum* :
> ```html
> <tag name="This html is read by Obsidian while it shouldn't.">
> This part of the document is now broken because the HTML tag is never closed.
> Lorem *ipsum*
# Lorem ipsum
Did you follow the troubleshooting guide? Yes
What is inside the code block should not be interpreted at all, but here, it is, and it breaks the rest of the document.
The HTML tag is interpreted, but since it’s not closed, it breaks the document.
Obsidian version: v1.8.9
Installer version: v1.6.7
Please note that this bug was found not by writing HTML, but XML. Obsidian interpreted the XML line as HTML because the syntax is the same, but there is possibility to close the line in XML.
Screenshot of the bug in a sandbox vault for illustration :
With regards
