There is a simpler method for moving a (link to X) from father note A to father note B ?
E.G.: I have a note A with active projects. When project X is finished, I want to move him to note B, with archived projects. Now, I must:
1. cut this link (X) from note A,
2. find and open note B
3. paste X in B
I guess the following will help.
Please read the part about extract.
And the workflow now is:
- enable the note composer plugin
- in note A, you select the link text, including
and]]
- right click the mouse or call the command pane
- choose “extract current selection” or “Note composer: Extract Current Selection”
- type and/or choose note B in the pop-up window and press enter
now in note A, the selected text(the link) is replaced with a link pointing to note B. you can delete it later.
Meanwhile, in note B, at the bottom of the note, an empty line and the selected text(the link) from note A is appended.
Thank you! It worked, on mobile too.
