Hi there - non-coder and first day on obsidian so bear with me
I’m using the Zotero integration with Obsidian with the aim of evaluating and synthesising a bunch of medical papers for a literature review for my research project. I’ve set up writing templates that auto-populate when I “open literature note”, for me to note-take in. I’d like to take notes in bullet points, and ultimately want this to populate into a dynamic table using dataview. I’ve managed to figure out how to get dataview to extract info from subheadings when i use :: and type inline, but as aforementioned, I want to use dot points, not sentence form, and i would like to be able to view it all in a table.
this is is the code i’ve got so far
TABLE
title AS Title,
thesis AS Thesis,
theoretical_framework_and_method AS "Theoretical Framework and Method",
research_design AS "Research Design",
quality_of_evidence_used AS "Quality of Evidence Used",
findings AS Findings,
gaps_and_limitations AS "Gaps and Limitations",
future_research_suggestions AS "Future Research Suggestions",
connections_and_critiques AS "Connections and Critiques",
my_notes AS "My Notes",
target_audience AS "Target Audience",
country_conducted_in AS "Country Conducted In"
FROM "papers"
SORT file.name DESC
I’ll attach some photos of what my tables look like, sometimes the dot points show up and sometimes not
I’ve scoured the forums (really have no idea how coding works so has been a lot of copy paste and chatgpt to modify codes haha)
I have tried the following code too
TABLE
file.link AS Title,
list(thesis) AS Thesis,
list(theoretical_framework_and_method) AS "Theoretical Framework and Method",
list(research_design) AS "Research Design",
list(quality_of_evidence_used) AS "Quality of Evidence Used",
list(findings) AS Findings,
list(gaps_and_limitations) AS "Gaps and Limitations",
list(future_research_suggestions) AS "Future Research Suggestions",
list(connections_and_critiques) AS "Connections and Critiques",
list(my_notes) AS "My Notes",
list(target_audience) AS "Target Audience",
list(country_conducted_in) AS "Country Conducted In"
WHERE contains(tags, "palliation")
SORT status DESC, read DESC
would be really grateful for a solution or workaround, obviously happy to use another plugin altogether, this was just the one i saw mentioned on https://medium.com/@alexandraphelan/literature-reviews-using-zotero-obsidian-66eba1565d78
thank you kind internet strangers!!!
