How to use block in obsidian? Some FAQ improvement suggest
in the post Link to blocks - Obsidian Help - Obsidian Publish , it said
To link to a block in a specific file, first type [[filename to bring up a list of matched files. After selecting a file, type ^ and continue typing to search for blocks to link to.
But my obsidian v0.9.17, In order to link a block, I need to type [[filename , select the file, and then press # and ^ to start search for the blocks.Not the way Help told me. :frowning:
So I think the Help should do some improve now…?
I don’t see the difference.
Indeed, this works as described:
Screen Shot 2020-11-28 at 11.08.19 AM
It also works if you use #^:
Screen Shot 2020-11-28 at 11.09.12 AM
And, just for completeness, it will only show headings if you just use #:
Screen Shot 2020-11-28 at 11.09.39 AM
Thanks bro. Maybe it is because im using folow setting
  • Use [[Wikilinks]] Nope
  • New link format Realtive path to file
Using folow Third-party plugins
  • Calendar
  • Natural Language Dates
  • Templater
then i press ^, it became
So the only way i use Link to block is perss#^ instead of press ^ :frowning:
this was fixed in 0.9.19
