How to use 'AND' function in DATAVIEW
I’m trying to create a query that would help me search for files that have ‘#writing’ and '#Sprout".
I am assuming that the AND function will be used but I’m not to sure how.
Here is the kind of file that I am trying to search for:
Here is an example query that I have tried:
Thank you guys!
Try this:
TABLE
FROM #Writing AND #Sprout
You’re correct that you can use AND function in Dataview but you can’t use it internally in the parameters of a function call. So the proper way to do it would rather look like:
```dataview
TABLE
WHERE contains(tags, "#writing")
  AND contains(tags, "#???Sprout")
Bonus tip: How to present code properly in a forum post
If you want to showcase either markdown, or code blocks, or dataview queries properly in a forum post, be sure to add one line before and one life after what you want to present with four backticks, ````. This will ensure that any other backticks (like in code blocks or queries) is properly shown.
Thanks to you too!
Much appreciated Denna.
