How to set default vault?
How can I set default vault? I have multiple vaults, but when I start obsidian, my first created vault loads. How to change this?
What OS are you using? Obsidian should reopen the last vault that you had open when you closed Obsidian.
Windows 10 22H2
There’s no “default vault”. Obsidian starts with the vault you used when you Quit obsidian last time.
Try to search some community plugin :slightly_smiling_face:
