I am wondering if there are plugins for it?
You don’t need a plugin for this. Just have the same file opened twice, move the second tab to a different pane. Set one file to “Source mode” and the other to “Reading view”. Now you the preview updated when you edit the file in “Source mode”. When you enable “Link with tab” and then choose the tab with “Reading view” even the scrolling of both views is synchronized.
To expand a little on @Denna’s post: a short way to open the current note in a new tab group is the “split right” or “split down” command in the command palette. (You can bind it to a hotkey or pin it in the palette or maybe add it elsewhere using the Commander plugin.)
“Link with tab” is in the note menu.
