I want to search excluding #learning
But AND is also searched as text
How can I search for sentences containing only #site and #test?
See the docs:
In short, and is implicit with a space and the search is on a note basis. There is no way to limit it to a sentence, but you can limit it to lines or blocks, which should give the desired result. See the docs for the syntax.
the inplicit one is not really an “AND” that avoids showing the single words match results.
I have the same need to find an “and”/ a workaround/ a tool where the matching results are only the notes where the words are found both together and not just concatenated as it is when u embrace them in the quotes as a sentence.
i hope it will come a workaround
