a751
#1
Is there a function in dataview that gives the index value of a particular element in an array?
For example: test:: one, two, three. some_function(test, “two”) = 1
In the documentation I found a way to retrieve an element based on the index: test[1] = two, but not the other way around.
Any tips are appreciated, thanks in advance.
Craig
#2
If you don’t mind using DataViewJS, you can use the built-in JavaScript indexOf() method:
a751
#3
I haven’t used dataviewjs so far but it seems like this is the only solution, thank you for your help, this does what I was looking for.
system
closed
#4
