Is there a way to reset customized hotkeys to their defaults?
I looked all around but didn’t find a way to do this. ![]()
I see that there’s a way to “restore” individual hotkey customizations, but this requires scrolling through all of them to find the ones that are customized.
Perhaps a “restore all” button could be added?
It looks like the Filter icon → “Assigned by me” is the closest approximation to this.
If you go into your .obsidian folder you can just delete the hotkeys.json file and it will revert to a fresh one. As far as I know that file is also storing all plugin hotkeys too.
(Make a backup first just in case. And likely while Obsidian is closed for best results. Or reload the app afterwards.)
