How to remove note preview when hovering
When the cursor hovers the Outline icon in the right column, the preview of the note is displays. I want to remove this. I find it really annoying :wink:
I’ve looked everywhere in the settings and could not find any way to remove it.
Any idea ? Thanks!!
Oh, and by the way, same thing when I hover the incoming links icon:
And when I hover the outgoing links icon, I still get an unwanted note preview, but from another note which relation to the current note, I don’t understand…
Thanks for any help!
The preview on hovering in the core page preview plugin. You can turn it off or adjust its options in Settings > Core plugins > Page preview.
Thanks @ariehen, I forgot to mentioned I already looked there. And everything is turned off:
And, I see that on this screen, on top, it says: “Require ⌘ to trigger page preview on hover”. However, I don’t need to hit ⌘ to get the page preview, I always get it as soon as the cursor gets on top of the icons mentioned in my previous posts.
Thanks for any help.
Enable all of the toggles.
:slight_smile:
One of those cases when the (seemingly) negative has positive outcome.
