Windows 11
Had a crash on a Windows machine and I need to recover Obsidian to a new machine environment (also Windows). Some time has passed, so I’m not sure which version of the software was in my backup. The backup consists of both \appdata\local\Obsidian and \appdata\roaming\Obsidian file structures. There is also a \appdata\local\obsidian-updater file structure that appears to be involved.
I tried a complete recovery to a new machine, but this failed with Obsidian hanging during startup with an empty square box on the screen. I read somewhere that just recovering the vault directories should work after Obsidian is installed, but it didn’t.
So, is there a procedure somewhere that lists exactly what needs to be done to recover the Obsidian environment? If not, I propose that there should be one (that is easily found).
