Hello,
I’ve created an account because I believe I have the aswer to the problem mentionned post #87664 (can’t add links either it seems)
But apparently since the post is old I can’t reply to it. Yet the OP might be interested in the answer I guess. What’s the MO in this case ?
Thanks in advance !
In this case, you can make a new post, and link to the post in question.
Or mention the post (I don’t know how to search by post ID) and if appropriate, we can open it back up. You can surround links by backticks `` and this will display the link without being a hyperlink. You’ll be able to link when your account has a higher trust level.
Thanks for your answer, the post is this one: https://forum.obsidian.md/t/user-steps-in-longform/87664.
Also to find a post by id it seems you can just go to https://forum.obsidian.md/t/<post-id>. Weird since the displayed URL has the post title in it, but it works !
Thanks! Ok, the post is opened back up.
This topic was automatically closed after 24 days. New replies are no longer allowed.
