How to organize a view of current projects tasks with dates
Hello, folks. Please, recommend me plugin that can help me achieve this. I have a file with lvl2 heading per project. Inside every heading I have a checklist with project steps/tasks with deadline date. Is there any plugin that can parse the file and make an overall projects view with current step (the first not checkboxed I think) with date. Would be great if it has option to click on step and switch to project heading with all steps it has.
I’ve already investigated kanban plugin and found it a bit out of my purpose.
I believe I’m looking for something like agenda view in emacs.
It’s crucial that plugin works with IOS version.
I’ll make it as quick as you did:
See linked vault. Download. Investigate how to customize for use case.
Dataview needed, works on iOS.
Check the Tasks plugin
This seems very similar to this request:
So use either of the queries from that post where you use instead of grouping by file, group/separate on the heading information on any given task.
Does that sound manageable? If not, please provide an example from one of your projects where you’d like to run a query like this.
