How to open folder as a Obsidian vault on right click context menu?
Hi! Is there a way to open any folder as Obsidian Vault on right click context menu right from the Finder or Desktop? (on Mac or Windows).
I know that i can manually add all folders in Obsidian app - but it is different order/sequence…
Maybe some hack using Alfred or other software?
Thank you very much
No, there’s currently no way to do that from any other place than the vault switcher. You need to at least have opened a vault once to enable Alfred workflows as far as I can tell (e.g. relying on the URI)
