How to open a specific note with a side bar button
Here is a solution I came up with to launch a specific note with a ribbon button
Load Filtered Opener
Load Commander
In Filtered Notes create a note set of a single defined note
In Commander under the Ribbon add a new command, use the “Pick Note”
command that is made available through Filtered Opener
That’s it
Also one could use the “HOT KEYS FOR SPECIFIC FILES” plug in too, but my goal was to have a button on the left ribbon.
Best Regards
-Tim C.
Check out my new plugin, obsidian-modal-opener. It allows you to use modal windows to easily open files and links in Obsidian. You can add specific pages and files to the Obsidian command, and by combining it with Commander, you can place it in the sidebar for quick access with just one click, as illustrated below.
