How to note xml?
I am noting a lot of XML and obsidian does not show it in preview. It takes XML tags like special characters. How to solve it so that <> and /> won’t be hidden anymore
You could use code blocks.
Use code blocks:
And if you want colored XML, you can install the ‘Editor Syntax Highlight’ plugin
