How to migrate from Remnote and fix issues + support spaced repetition history?
I want to move from Remnote, but don’t want to have to restart all my spaced repetition from 1 day. Does anyone have a way to do this export well?
Online scripts like PKMigrator are quite out of date at this point, so I’ve just used the default MD export and import. Things I had to do manually:
  • all my tags were empty, I had to refill the important ones
  • all my spaced repetition was gone, it just inserts notes with a ‘→’
  • all notes in portals are duplicated but labeled ‘Portal’
  • the Obsidian graph is littered with nonsensical links
  • my massive Daily Document is littered with random colors, looks like this:
  • my obsidian graph is basically a cluster of daily documents, then all my other docs are unconnected to anything around the edges. would be nice to get some connection/density automatically especially via my portals or other links
Does anyone have recommendations for how to improve this import process?
