How to manually adjust Obsidian note margin size
I’m trying to make custom-scalable margins so I can fit larger images and wider text lines WITHOUT disabling ‘Readable line length’.
Tried CSS code blocks from ChatGPT but they didn’t work and I don’t know CSS at all so idk what I’m doing.
Readable line length needs to be enabled for any of these snippets to work.
For the default and almost all community themes, you can use these (for example) on a per-note basis. The class, wideish-view (no dot) etc., goes in the cssclasses section for any notes you want to change. The class name (.wideish-view, etc.) can be changed as long as it doesn’t conflict with another class in that vault.
.wideish-view {
    --file-line-width: 900px; }
.wide-view {
    --file-line-width: 1200px; }
.full-view {
    --file-line-width: 100%; }
Obsidian_87mjv1CQm9
If you want to change the readable line length of all notes in a vault, replace the cssclass with body.
body {
    --file-line-width: 1200px; /* default RLL is 700px */ }
Alternatively, if you want all notes full width but only some a custom width, we can flip it around:
body {
    & .rll { --file-line-width: 700px; }
    & .wide1000 { --file-line-width: 1000px; }
    & .wide1200 { --file-line-width: 1200px; }
Lots of options to try!
https://help.obsidian.md/snippets if needed.
