Im new to Obsidian and I’ve logged into Obsidian on my laptop phone and computer so i can do my work anywhere i need but i need to make the vaults remote? I dont know how to do this and it is quite fustrating.
Out of the Obsidian box, the solution is this: Obsidian Sync.
However, there are also cloud-based solutions (like OneDrive). This forum should have plenty of posts on this topic.
Cheers, Marko
I’ll just add to what DiCaver said.
Obsidian doesn’t store anything for you. Unless you buy and use Obsidian Sync.
The only reason you need to log in to your Obsidian account is to access paid products like Obsidian Sync, Publish, etc. or if you purchased the Catalyst license.
If you choose to use 3rd party cloud tools like OneDrive or iCloud, make sure they are set not to automatically remove your files from your local device.
