Make this css snippet work in edit mode and preview mode.
Idk how to do it, it shows in preview mode but in edit mode it is just black backgorund instead of transparent
This is the snippet:
.theme-dark img {
filter: invert(1) hue-rotate(180deg);
mix-blend-mode: screen; }
The above snippet looks alright for me in Live Preview and Reading view.
You could try different images or remove the mix-blend-mode section.
mix-blend-mode: screen; worked for me, but mix-blend-mode: darken; created nearly black images in Reading view. Possibly something with that.
This is in edit mode:
And this is in preview mode:
I don’[t want the black background in edit mode
Ahh, I see now. mix-blend-mode doesn’t appear to do anything in the editor. I didn’t notice it with my original images.
If I find out why or a workaround, I’ll report back.
I’m not entirely sure why, but the issue seems like it’s the div that the image is in. give this a try:
.cm-content > :has(> img) {
background-color: var(--background-primary);
.theme-dark img {
system
Closed
6
