How to make a wide dashboard to display ![[embeded]] callouts side by side
I wrote some custom CSS to create callout boxes that float right. I would now like to create a dashboard environment that is extra wide (say 200%) and I can ![[embed#^1234]] a copy of my callouts into so they float left and I can scroll sideways to see 10-ish of them side by side.
Originally I thought I would simply place the ![[embeded link]] into a custom div block, but that hasn’t been working as the Obsidian ![[embed]] seems to just ignore the div.
CSS:
.infodash {
width: 200%;
height: 100%;
overflow: scroll;
.infodash .markdown-embed {
float: left;
border: none !important;
padding: 0 !important;
margin: 0 !important;
Markdown:
![[infobox to embed]]
I tried the same thing by embedding inside of another callout, which worked, but created a staircase effect. with each embeded image slowly dropping by an additional line break (but they did float left!).
CSS:
/* Set Box Style*/
.callout[data-callout=“infodash”]{
width: 200%; /* Adjust the width of the callout box /
float: left; /
Floats the callout box to the right /
margin-left: 10px; /
Adds space between the callout box and the text OUTSIDE the box /
border: none;
padding: 0px; /
Adds space between the dashboard and the text INSIDE the box */
/* Obsidian Custom Variables /
–callout-icon: lucide-info;
–callout-color: 126, 154, 170 0; /
Sets color “theme” for box (header text and background) */
/* Removes border and padding for embedded files*/
.callout[data-callout=“infodash”] .markdown-embed,
.callout[data-callout=“infodash”] .file-embed{
float: left;
Markdown:
>[!infodash]
if you just want to use, you may check out my css snippet.
Multi Column Callout | Modular CSS Layout
or if u really want to make it your own, u can have a look at the css code here (i point to the relevant section)
obsidian-modular-css-layout/MCL Multi Column.css at ac6b6ae2641ee77877960e191db0a784bf13f651 · efemkay/obsidian-modular-css-layout · GitHub
