How to keep/always have # in front of Tags in properties
I like to have tags preceded by the #, to keep them consistent with inline tags, so my typical tags in Properties look like this:
tags:
  - "#books"
  - "#reference"
1: adding tags during note editing
Obsidian adds tags in the format I want if I type # in the tags properties field
Is there a way to force Obsidian to always behave as when I type the #?
This would be much faster and less error prone (less chance to have some tags without the #)
2: adding tags to multiple files
Sometimes I need to apply tags to multiple files at the same time and I use the Multi Properties plugin but it adds tags like this:
tags:
  - books
  - reference
I tried the Linter plugin but it does the opposite of what I need: it removes the # from tags in properties. I would need an AntiLinter.
I did a multi file search and replace with a text editor but I’m hoping there is a better way.
There is no setting in core Obsidian to achieve what you need.
But you can easily hack the main.js file of the said third-party plugin:
Disable the plugin, navigate to the plugins folder of your config files and to the ‘multi-properties’ folder, and open the main.js file in an external editor.
Find
function cleanTags(str) {
  let cleanStr = str;
  for (let index in KNOWN_BAD_CHARACTERS) {
    cleanStr = cleanStr.replaceAll(KNOWN_BAD_CHARACTERS[index], "");
  return cleanStr;
Replace this function with:
  let cleanStr = str;
  // Removing known bad characters
  // Adding '#' before tags value
  cleanStr = "#" + cleanStr;
  return cleanStr;
  • The double quotes will be added by the plugin, so no need to add them here.
Save the main.js file. Re-enable the plugin and now it will add "#tagvalue" in your files.
These added lines will be overwritten again when the plugin gets updated. So quit Obsidian, make a copy of the plugin, rename the plugin id and the name of the plugin (to any descriptive name) in the manifest.json file and add that new id in the community-plugins.json file. Make sure you follow the syntax: comma after each line except the last one.
This way one can make sure the modified plugin’s main.js will not be overwritten.
Thanks a lot, It works!
Adding individual tags in an open file is still slow because I have manually type the # before selecting the tag, but now I can do bulk tag edits with a lot more ease.
