How to implement ability to create nodes/links in graph?
I want to hire developer for implementing ability to create nodes/links in graph. Is it easier to make that using your API or just to create external app, which can analyse Obsidian vault directory and build needed graph from it?
Sorry, I am not quite following. Do you want to be able to create nodes and links from the graph view? If so, there is a feature request for this already: Add nodes and edges from graph view
I know about the feature request. I just want to understand, what is the easiest way to implement that?
@apris It would be better for this topic if you posted your question to the feature request so if/when this issue gets more attention, all discussion is in one place.
We use the help category generally for questions about existing features.
