How to Grab Values from the Linked Note?
I like to drink, especially alcohol liquer.
I drink different drinks almost every day, and I want to use Obsidian to record information and tasting notes about what I drink, something I’ve been doing manually.
Here’s what my frontmatter of drink notes look like
Budweiser
ABV: 4.5
Taste: Just normal lager taste, a little bit lighter
And in the frontmatter of my daily note, I have this part
2024-07-10
What_To_Drink: [[Budweiser]]
How_Much: 335
What I want is, [[Drinked]] inside a document called [[Drinked]].
Column 1 will search for documents in the daily notes where What_To_Drink is not empty,
Column 2 gives me the drinks consumed that day.
Column 3 multiplies how_much by the abv to calculate the actual amount of alcohol consumed.
Column 4 brings up Taste.
First, I can make column 1 and 2 easily.
TABLE WITHOUT ID link(file.link, title) as "Date", What_To_Drink
FROM "Daily Notes"
WHERE What_To_Drink != null
However, I found it quite difficult to create a third column.
If this were in the [[Budweiser]] document, I could make it like this
TABLE WITHOUT ID file.link as "Date", How_Much*this.ABV/100 as "Actual Alcohol"
FROM [[#]]
but It’s not. How can I make it?
One step forward. There are still issues, but whatever…
TABLE WITHOUT ID link(file.link, title) as "Date", Drink, How_Much as "How Much", Drink.ABV as "ABV"
FROM "Diary"
WHERE Drink != null AND How_Much != null
This will create a table that looks like this
Date Drink How Much ABV
[[2024-07-16]] [[Budweiser]] - 350 - 5
[[2024-07-17]] [[Corona]] - 350 - 5
[[2024-07-18]] [[Jack Daniel’s Old No. 7]] - 45 - 40
[[2024-07-19]] [[Smirnoff No 21]] - 30 - 40
[[2024-07-20]] [[Cham Iseul]] - 150 - 16.5
I was really excited to get this far, but then I ran into another problem.
When I added How_Much*Drink.ABV/100 as "Volume of Alcohol" after the ABV, I got the error below.
Dataview: Every row during final data extraction failed with an error; first 12:
    - No implementation found for 'number * array'
I’ll have to do a little more research
Final touch.
I don’t know why on earth Drink.ABV is implemented as an array, but I simply treated it as sum(Drink.ABV).
The end result is this
TABLE WITHOUT ID link(file.link, title) as "Name", Drink, How_Much*sum(Drink.ABV)/100 as "Total Alcohol Volume"
FROM "Diary" OR [[#]]
