How to get URI of note with spaces and special characters in name?
Hi,
apologies for maybe a stupid question, but…
In both my Vaults and notes names I use 1. spaces and 2. Latin-2 (special) characters. How can I create (find?) URIs for such objects (vaults, notes)?
That would be extremely helpful in my workflow (Keyboard Maestro, etc.)
Many thanks for some advise,
Andy
I do most of my automation with Alfred and I usually incorporate a very simple python script that uses urllib. However, KM seems to have some kind of built-in function, so it may be even easier for you.
Many thanks, it works :slight_smile:
@macedotavares and @wodecki, if you use Alfred, check out my workflow. It uses encodeURIComponent to encode special characters and spaces (see doc here).
Awesome. Thanks!
