Hi. I use Obsidian in complex with Keyboard Maestro, Alfred, etc.
I work on scripts that can interact with my vault on background.
I want to set note title into variable.
Maybe I miss something, but I’ve stuck with problem that I can’t send info about notes I’m currently work with to my automation apps and scripts.
That things I tried, and I’m not satisfied with it:
  • Toggle in Preview mode and press “Shift+Tab”
  • execute mouse click at position
  • OCR
I prefer to find independent solution from simulating interface controls in my scripts. If such option exists I’d like find way to get note title in background.
So questions:
1.Does any options to get all note titles of every panel on screen?
2.Does any options to get current active panel note title as a string?
Ok. I researched what my vault contain and found a solution.
In my vault I found hidden directory named .obsidian that contains JSON files.
So here path to file that I wanted to read: YouVault/.obsidian/workspace
Now I can read JSON information to get note title, active tab bool, last open files and more of my current workspace. I think I will use python to play with it.
Anyway, thank to developers and community for help and maintain so beautiful app :wink:
Was about the suggest that, glad you found the json file!
