I have a vault with many plugins customised and edited and want to try to export a vailt with ALL plugins and ALL data in the vault to use on another device
I tried looking through files to check out what i can’t do.
i apologise but i was inmplying to go to the source folder of the obsidian on the device and asking if plugins would be transfered after i copied the source files, not doing syncs to like git hub
If you go into your computer’s file system and find your Obsidian vault, you’ll find a folder called .obsidian which contains all the plugins and configurations. If you can’t see .obsidian it’s still there, it’s just hidden. If you’re on Windows I think you can right click and select something like “show hidden folders”. Anyway if you just copy the entire vault in the file system, you can move the whole thing and that’ll bring the configuration files too.
Depends on the other “device”.
If you tell us your type of device, we (someone) can be of more service.
I used different kinds of local sync to iPadOS for instance. Actually, you can use ’ X-plore File Manager’ on Android (better make a zip of what you want to transfer and unzip on the destination device).
If it’s another PC, use a pendrive/external hard drive.
