Hi ! I have been loving the folder bases from make.md! they’re really useful in a project I’m working on.
I have a folder table that contains creatures from my bestiary, with a “Zone” property that I manually fill out.
I have another folder table for my zones, and I would like to embed in the note for each zone a customized view of the bestiary table, so that only the creatures from this zone appear.
I know how to make the filter thing ( adding a filter “Zone” is “zone_name” ), but I can’t figure out how to embed this specific view into the other note!
I know that in classic Obsidian you normally use the embedded code "![[Base_Name.base#View]] but it plainly doesn’t work and the view stays on the default view of my table.
Thank you so much for your help! ![]()
