I am used to referring within a file to its fragments via an anchor link or a named link (it’s created using the ^
symbol) and via a hash link or a fragment identifier link (It is created by using the #
symbol).
For example, I just need to add a [[^fragment]]
link inside the file to move to and highlight another piece of ^fragment text
in the file.
I expected similar behavior from canvas. So that I could refer to other independent nodes in the file without directly pointing to them using edges between (node-to-node).
What should I do? I want to reference other nodes by click on their internal text for automatically scrolling to another text in another nodes (as implemented in maps).
