Hello! This PR addresses the following issues: #581, #556, #451, #426, #387, #28…4, #93, introducing several new features:
- Cloze hints (#451, #93)
- New Cloze Types:
- Numbered Clozes, just like Anki (#93)
- Overlapped Clozes (#451, #426, #284)
- Custom Cloze Patterns (#581, #556, #387, #93)
The implementation leverages the [Clozecraft](https://github.com/MotaOcimar/clozecraft) package, a Cloze parser and Card formatter developed by me specifically for this purpose. Feel free to explore, ask questions, and contribute. Your feedback is highly appreciated.
I've opened this PR as a draft because there are still a few tasks pending:
- [ ] Fix failing tests
- [ ] Create tests for the other cloze types
- [ ] Decide which Cloze Patterns will be delivered by default with the plugin
- [ ] Play with the new features to ensure they work as expected. Fix any bugs and add tests for them if necessary
- [ ] Gather your feedback
# Features
## Cloze Types
### Simplified Clozes
Simplified Clozes are the Cloze Type we have been using so far. They keep working as before, but now you can add hints to them. That means each card will occlude one deletion, showing its hint if available, while leaving the other deletions visible.
For instance, the following note:
This ==note== doesn't need to have ==number==^[hint] on clozes
Will generate two cards, with the following fronts:
1. `This [...] doesn't need to have number on clozes`
2. `This note doesn't need to have [hint] on clozes`
And both will have the same back:
This note doesn't need to have number on clozes
### Classic Clozes
Classic Clozes are the same as Simplified Clozes, but they also have a sequence number used to sort and group deletions.
This is a ==cloze==^[a hint][^1]. This is ==too, but without hint==[^2]. And this one is asked ==together with the first cloze==[^1].
Will generate three cards, with the following fronts:
1. `This is a [a hint]. This is too, but without hint. And this one is asked [...].`
2. `This is a cloze. This [...]. And this one is asked together with the first cloze.`
This is a cloze. This is too, but without hint. And this one is asked together with the first cloze.
### Generalized Cloze Overlapping
The Cloze Overlapping Generalization allows you to dictate the behavior of each deletion individually. Each deletion has its own set of actions that indicate how it will behave on each card:
- `a` for ask (hide the deletion answer in the front of the card while showing it in the back).
- `h` for hide (hide the deletion answer both in the front and back of the card).
- `s` for show (show the deletion answer both in the front and back of the card).
==Some context for items 2 and 4, but that could spoil items 1 and 3. Note that this doesn't even need to be asked==[^hshs]
- ==Item 1==[^ashh]
- ==Item 2==[^hash]
- ==Item 3==[^hhas]
- ==Item 4==[^hhha]
In this example, 4 cards will be generated, where items 1 to 4 will be asked sequentially. When asking Item 1, all other text will be hidden. When asking Item 2, just the Item 1 and the context will be displayed. When asking Item 3, only the Item 2 will be displayed. Finally, when asking Item 4, both the Item 3 and the context text will be displayed.
## Custom Cloze Patterns
You can now create your own Cloze Patterns. For instance, to emulate Anki-like clozes (e.g., `{{1::text::hint}}`), simply add the following pattern to your settings:
{{[123::]answer[::hint]}}
Brackets `[]` delineate where the sequence number and hint will be placed, along with any additional characters of your choice (e.g., the `::` in the example above). Clozecraft automatically generates a regex pattern based on your custom pattern. Sequence numbers are identified by finding numbers between brackets, hints by finding the word `hint` in brackets, and the deleted text by finding the word `answer`.
Here are some examples of custom patterns:
| Explanation | Pattern in the Settings | Simplified Cloze Usage | Numbered Cloze Usage | Generalized Cloze Overlapping Usage |
| Anki-Like Pattern | `{{[123::]answer[::hint]}}` | `Brazilians speak {{Portuguese}}`<br><br>Or, with hint:<br>`Brazilians speak {{Portuguese::language}}` | `Brazilians speak {{1::Portuguese}}`<br><br>Or, with hint:<br>`Brazilians speak {{1::Portuguese::language}}` | `Brazilians speak {{a::Portuguese}}`<br><br>Or, with hint:<br>`Brazilians speak {{a::Portuguese::language}}` |
| Highlighted pattern with hint and sequencer in footnotes. Note that you can use brackets as part of your pattern, but you need to escape them. | `==answer==[^\[hint\]][\[^123\]]` | `Brazilians speak ==Portuguese==`<br><br>Or, with hint:<br>`Brazilians speak ==Portuguese==^[language]` | `Brazilians speak ==Portuguese==[^1]`<br><br>Or, with hint:<br>`Brazilians speak ==Portuguese==^[language][^1]` | `Brazilians speak ==Portuguese==[^a]`<br><br>Or, with hint:<br>`Brazilians speak ==Portuguese==^[language][^a]` |
In your settings, you can add multiple patterns at once, separating them with a new line:
Then, you can use them in your notes:
This note has both ==highlighted clozes==[^1] and {{2::anki like clozes}}
And this note has both ==highlighted clozes==^[footnote hint][^1] and {{2::anki like clozes::anki like hint}}
Remember, deletions must be of the same Cloze Type. You can't mix, for instance, a Classic Cloze with a Simplified Cloze in the same note, as they employ different ways to sort and identify the cards.
