I revise my notes in obsidian slides and usually my first slide is table of content.
What I’m trying to do is
I want to create toc using markdown links as it works with most of markdown editor. I don’t use wiki links as it doesn’t works in many online editor.
I can’t create a link to one of my headings.
## TOC
- [display:flex](<#display flex>)
- [referrerpolicy](<#[referrerpolicy] html 07 anchor md referrerpolicy>)
- etc
### display:flex
The `Display:flex` allows the element and it's children to have flex properties but the container itself stays block level element.
### [referrerpolicy](./html_07_anchor.md#referrerpolicy)
^564bbd
Specifies which referrer to use when fetching the resource
**value:**
- `no-referrer`
- `no-referrer-when-downgrade`
- `origin`
- `origin-when-cross-origin`
- `unsafe-url`
so what is the syntax to link to the ‘reffererpolicy’ heading ? so that when i hover over the link, it will show a quick preview or when click on the link it will scroll to the heading.
[referrerpolicy](<#[referrerpolicy](./html_07_anchor.md#referrerpolicy)>)
[refer policy](%5Breferrerpolicy%5D%28.%2Fhtml_07_anchor.md%23referrerpolicy%29)
[referrerpolicy](<#^564bbd>)
do i have (use \) to escape some character to do this. how do you escape character in the headings ?
