How to create headings/subheadings that are *not* included in outline
What is the best way to create a heading or subheading (visually similar to H1-H6) that is not included in the outline?
Some of my subsections are not important enough to be displayed in the outline, but I still want them to be separate sections in the document body.
Do I need to use HTML for this?
The main output is Obsidian Publish, if that makes a difference.
Thank you.
That’s a kind of an odd request, but I reckon you can do it using some HTML elements, like doing a <span class="fakeH1">Fake heading</span>, and then have a CSS snippet simulating the heading formatting.
I’ve not heard of any ways to eliminate the header from appearing in the outline through plain markdown.
For lower level headings you could perhaps get by doing bold and/or italic on a line of its own. Or possibly use HTML like <big>Bigger text</big> or <large>large text</large>, but do remember you can’t put other markdown inside of the HTML elements in any case.
Try using HTML headings (<h2>, etc.) as you suggested. I don’t use Publish, but in local Obsidian they don’t appear in the outline sidebar. Not sure if it works the same in Publish but it’d be easy for you to check.
