How to colour thing differently in graph view
### What I’m trying to do
Recently I’ve been using Obsidian to help me organize part of the RPG system I’m working on, and one thing I did was create a new folder to separate the attributes from the creatures, but when I tried colouring it differently than the creature folder on the Graph View, it didn’t show it, any ideas on how I could fix it?
### Things I have tried
I’ve tried using paths to fix it, but it didn’t do it, please know that I’m kind of new to Obsidian, and that any tip is welcome :)!
It would help if you could share more details about your folder structure, what your graph currently looks like, and what you want it to look like.
Oh yeah, I’m sorry for not posting it altogether, I’ve recently been moving and it consumed me, I’ll post it right when I have time
The picture above is the entire graph view, the one on the right is part of a group “A”, and the one on the left is part of a group “B” (like shown below)
{FD8413F3-A689-4E97-990F-B8EF4C0CFEFA}
{57225455-03DA-4D96-A373-2CC092A50D17}
The idea is to make B have a different colour than A.
Is this what you want?
Yes!
Also, sorry if it’s something really easy to do, I’m really a starter to Obsidian
And I’ve already done that, see:
No worries at all; asking questions is always welcome.
So, just to clarify what you issue is, left (B) should be completely yellow? and right (A) should be completely red ?
Yes
If it helps, the green-ish dots are tags
I’m not sure if this is universally true but at least for me, I usually need to put the path in quotes for it to work, ie.
:yellow_circle: | path: “A”
:red_circle: | path: “B”
If you are trying to also get the tags to be a specific color, you need the Extended Graph plug-in for that.
I’ll try that, thanks!
Quotes are only necessary when searching for complete phrases (Search - Obsidian Help).
In the core Graph View you can also create groups for tags to apply a specific color.
Okay.
With the Tags toggle you can choose whether tags are shown or hidden in Graph View. You can also assign a colored group to any tag.
If the group colors still aren’t displaying correctly, I guess the first group is being applied to all of them, because the note names contain an A. Try using path:A/ and path:B/. This should filter only the files inside the specific folders.
It solved it! Thank you!
