How to close current note in a stacked Tab Group
I am trying to close the top / current note in a stacked tab group
-Tapping the X on the Tab
-Tapping Shift X
Looked for a plugin
control W works on Windows
That closes all the notes opened under the same tab. I am trying to close only the active note.
Thank You
Tapping the X should work. Perhaps you’re using a community theme that has a bug, or a CSS snippet or plugin with an unfortunate side effect.
Control W should close the tab, too. But maybe something else has taken over that hotkey? You can check in Settings > Hotkeys. In the search box there, press the keyboard icon, then do Control W to see what is using it.
Besides the X, there are other ways to close the tab:
  • Right click or long press the tab (the part with the title in it) and choose “Close”.
  • In the command palette, use “Close current tab”.
Thank You for teh response
