How to close a vault within Docker?
One of my instances of Obsidian is using https://hub.docker.com/r/linuxserver/obsidian, which enables me to edit my main vault(s) through Raspberry pi on my TV. Rather neat solution.
However, I’ve experienced a problem related to how do you close a vault from the keyboard when using the default hidden window frame option?
Since 1.7 (or so) when switching vaults it opens a new vault without closing the other vault. And when within the docker instance this becomes a problem if you want the vault closed for some reason. Like syncing, manual editing outside of Obsidian, and so on.
Sp therefore this question on how to close a vault from within the docker environment? And potentially, how do you switch to the other vaults open already?
