Brute changing using this CSS snippet makes text dependable on dark/light theme(make white text unreadable on light theme and vice versa)
.markdown-preview-view code {
color: #FFF;
Is there more ‘correct way’ of changing code text to default text color?
Depends… You use default theme?
If yes, for default text color you can use this
color: var(--text-normal)
Thanks, that is nice solution!
Is there a way i can use 2 custom colors for code for light and dark theme?
Yes, there’s a way.
With var(--text-normal) the color behaves as the normal text: almost black in light theme and white in dark theme.
If you want another colors they need to be defined in this way:
:root
  --mycolor1: #F9E300;
  --mycolor2: #ef4343;
.theme-light {
  --color-code: var(--mycolor1);
.theme-dark {
  --color-code: var(--mycolor2);
Then, instead of color: var(--text-normal) you place this:
color: var(--color-code)
