How to change appearance of embedded note section
Hi,
@ariehen helped me a lot with a css snippet, which allows to show the source title within the embedded file / file section (here is the original thread).
This is the result of that css snippet, when I embed the header “Library” of the note “Math” (source-mode view: ![[Math#Library]]):
what you see is in green color is the note title (“Math”) and the header (“Library”) of the embedded file section.
and here is the css snippet:
.markdown-source-view .internal-embed::before { /* .markdown-source-view um im Reading-view die source nicht anzuzeigen, nur im Live-Preview */
    content: attr(alt);
    font-size: 1.2em;
    font-weight: 500;
    color: rgba(67, 180, 54, 0.706);
Now here is my question
you see in the embeded note section “Library” twice:
  1. in green: as part of the css snippet, what is exactly how I want it
  2. in red: the header as it is implemented in core
Question 1:
Is it possible to get rid of the red header in the embeded note?
Question 2:
if that’s not possible, how do I have to modify that css snippet, to get rid of the green “library”?
Thanks in advance,
kind regards,
Silias
Hi SiliasOS :wave:
I’m glad the snippet is still going strong. I’m actually making use of it in a few places now as well.
Removing headings in embeds should be easy enough. Give this a try for all embeds and all heading levels:
.markdown-embed :is(h1,h2,h3,h4,h5,h6) {
    display: none;
An alternative, if you wanted to selectively remove the headings per-embed, you could try this version that uses alt/attribute text:
.internal-embed[alt~="no-heading"].markdown-embed :is(h1,h2,h3,h4,h5,h6) {
    display: none;
and the embed link would be written as ![[math#library|no-heading]].
wow, this is beautiful!!! :heart_eyes:
Thank you very much! :slight_smile:
Not sure whether this matters in your use case, but I believe that CSS will remove any header in your embedded file. Not only the first one.
In other words if you had 7 headers in your file to embed, all 7 would disappear. This can, I think, be countered, but I’m not sure if it’s any point in your case or not.
Yeah, this will wipe out all headers.
Hi,
now I’m at that point, @holroy pointed out: this css-snippet removes any header in all embeds in Obsidian… - which is kind of a disadvantage.
=> that brings up an alternativ question:
My issue is, if I embed a note-heading (e.g. ![[Math#Library]] like in the example from above, the string of the heading shouldn’t be visible twice (in the example from above: the heading “Library” is visible in green as result of the css-snippet AND in red as standard heading).
So instead of removing all the headings (the red “Library”) with an additional css-snippet, it would be better to modify the original css-snippet
    content: attr(alt);
    font-size: 1.2em;
    font-weight: 500;
in that way, that only the file-titel would be included, but not the heading if the embed points to an heading.
=> that would mean to somehow delete the green “Library”.
Is that possible?
I’m a little uncertain whether the element you want to hide the embedded title or the first heading of the embedded section. If it is the former, then try the following:
.markdown-source-view .internal-embed .embed-title {
  display: none;
