how to call an added command using addCommand from ribbon
OR
how can I do an editorCallback like functionality from addRibbonIcon
Is this possible or am I doing something completely wrong ?
this.addCommand({
name: 'Sample editor command',
editorCallback: (editor: Editor, view: MarkdownView) => {
console.log(editor.getSelection());
editor.replaceSelection('Sample Editor Command');
this.addRibbonIcon("dice", "Print to console", (evt: MouseEvent) => {
// how do I call "sample-editor-command" here ?
8 days not a single reply.
seems like this is not doable , there might be some unexplored way thats needs some digging.
Just in case someone else needs this, here’s the solution.
this.addRibbonIcon('dice', 'To Live API', () => {
app.commands.commands["obsidian-to-api:send-all-to-Live-api"].editorCallback();
//basically trawl through the app object, ensure you select command using the bracket notation and call the function [either callback or editorCallback()]
// so more generically ==> app.commands.commands["plugin-id:command-id"].editorCallback()
There is probably an easier way but this is the way I found.
