How to browse through notes using arrow keys
I want to scroll through all my daily notes using the arrow keys. Alt + arrow key only works when the note has a white rectangle around it on the sidebar. If I delete a note the white selection rectangle disappears. What is the right way to browse through your notes?
I tried mapping hotkeys, downloaded the journal plugin- couldn’t find an option.
Not specifically for daily notes, but give the
a try. Here I set a hotkey for Quick Explorer: browse vault and am only using the arrow keys to up/down left/right and Enter to open the note.
Obsidian_vz2I5aKCF8
I use Quick Explorer external plugin: Go to Next/Previous file in Folder.
