How to bring up right click menu on iOS / iPadOS?
Hi, in general on iOS it appears the right click menu is triggered by a long press. In Obsidian, on my iPad this only brings up a magnifying glass. I’m trying to bring up the menu which would allow me to insert a table, or add rows to a table, etc. Is this possible on an iPad?
Many thanks,
AFMA
On iPhone, it is the toolbar above the keyboard. It’s a little bit different, but it has the same functionality. You can slide it left and right.
If you don’t see “insert table,” you have a settings “wrench key” where you can add/remove buttons.
Cheers, Marko :nerd_face:
