How to apply different fonts for different languages
I am trying to export my notes in different formats from my vault. The include Farsi characters. I have the alignment covered using Dynamic RTL plugin , It only works on exporting to PDF, it is not perfect but it helps a lot for my problem. Now I want to have each language use a different font. For example I need to apply B Nazanin for the Farsi part of characters in my note and also use another font for the Latin characters in it.
I am using this wonderful CSS to format my exports, but I can’t control which font applies to which language.
There are solutions like this to applying unicode range but the ones I have found are addressing the font file. I am not sure how should I address the font in CSS in this way as it is applied inside the obsidian.
